ONEX #54 Web Site
Date:  10-15-2012
Number of Hours:  1.00
Manual Reference:  L01
Brief Description:  Updrill axle spacers
Bought a Harbor Freight drill set that included a 3/4" bit (HF item 00527). The 8 piece set has drills from 9/16 to 1" in 1/16ths and was about the cost of a 3/4 bit only at the hardware store. There were some comments on the HF site about the trueness of the bits. I checked the 3/4" bit and it was about .010" out of true. Sonex indicated the hole size was not critical, so I used the bit and ended up with a nice fitting hole on the axle (which is about .744").
Mounted the L01-11axle spacer in a lathe, the 3/4" bit in the tail stock, and bored the spacer out to 3/4".
Updrilled one of the mounting holes on the spacer. I'll updrill the other with the axle, gear, and one mounting bolt in place.
Updated drawings with entries from Onex Revision Log dated Oct 9, 2012. The ONX-T01 rev B 10/9/12 entry adds details -06 and -07, but the details were not included. Also entry , ONX-T06, rev B, dtd 10/9/12 refers to dimensions on ONX-02 rev D, but there is no rev D (or rev C) listed on the revision log. Need to clarify these with Sonex.
